I would like to know if there is a failure pattern called "Domino failure" in Push Over Analysis from which we can identify which member/joint failed first and then failures of member/joint connected to first member/joint in sequence ?
Hi DD,
Program is going to report results for every step in the analysis.Furthermore, you are able to define this step.
Please let me know if you need any further assistance.
Rafael Lara
Answer Verified By: DD
Thanks Rafa. I am interested in learning the data syntax inputs of Every types of Analysis. I mean to say Datagen formats. Is there any reference kindly share. I'm interested in In-place, Seismic, Faatigue & Pushover
