I currently working on my undergraduate final project which is simulation to jacket and topside transportation, I used the vessel from Ultramarine library (brg300) to generate transportation the jacket. So, far I tried to insert model jacket.dat and topside.dat can't be read by the system. When I run the program I have error:
Defining Jacket with file jack.dat
setting orientation
Finished defining jacket
*** WARNING 1 ERROR Occurred While Reading the Model
*** ERROR: Relative Name
*** ERROR
How it should be if I want to get the structural analysis with tiedown?
I really need your help. Many thanks.
platformtrans.rar
Hi Aisyah,
MOSES comes with over 400 files to use as examples. There is a directory dedicated to installation operations. Please see
C:\Program Files\Bentley\Engineering\MOSES CONNECT Edition V12\hdesk\runs\samples\install
You probably have V11 or V10 but the rest should be the same. The directory has three sets of files that transport a cargo. One of the files transports a jacket.
I will answer questions on those files. Bentley Communities is NOT here to review and correct clients files.
Georgina Maldonado
The model can be model successfully.
Thank you for your advisement.
Aisyah
