Actually , iam new user of Moses. I see on the moses modeler after making the model , i can save it as moses DAT file. Also , the same way with stability , however in moses stability ,ifind that i will save may be 4 dat file " compartment , loadcases, mesh and damage stability ". so is there is any way to make combined DAT file from these files?
Hi Sabry,
At the moment there is not a way to combine the DAT files. You will have to write a dat file and use the "&insert filename" command for each of the files.
The Stability application does not know when you will be using the data. That is why it creates separate files for this information.
We will be changing this in the future.
Can I ask what you are trying to model? If you want to contact me at georgina.maldonado@bentley.com that is acceptable.
georgina maldonado
so , i try to compare the results if i make the modeling scripting and Making the model on Moses Modeler , meshing and save it as Dat File , isee there is no difference beween both of them . So , if i want to make the stability also in Moses stability Module Instead scripting it and adding theses data to Model dat file . can you illustrate these posibility. and if yes, can you show me how i can write this command "&insert filename" .
