Create Damage Case with VBA Stability Automation
I am working with the stability automation tool to automatically add a damage case to my maxsurf stability model, and then populate the tank status based on whether it is damaged or intact. This is all being driven by a piece of VBA code.
At the moment I can add the new damage case with my desired damage case title.
However when it comes to editing the tanks to update the status (damaged or intact), I am struggling.
I am looking at the functions below to help define the tank status based on which damage case is selected.
  • DamagedPercent(tankIndex As Long) As Double
  • DamagedPercentByName(tankName As String) As Double
I keep getting an error suggesting I have a "Bad Index", even though the tank name(ie tank 2) is correct or the tank row is correct (ie row 2). Below is the line of code simplified suggesting I want to change the row 2 tank definition for the active damage case = damaged.
hmApp1.DamagedPercent(2) = 100 <---corresponds to "Damaged"
or
hmApp1.DamagedPercent("Tank 2") = 100 <---corresponds to "Damaged"
Any ideas would be appreciated.
Thanks.
  • Hi Oliver,
    What have you defined hmApp1 as? is it set to be ...stabApp.Design.DamageCases(2)
    Do you have partial flooding enabled in your model? Case | Enable Partial Flooding.
    Note that there is also a Boolean choice for IsDamaged, more suitable for cases where you aren't using partial flooding.
    Here is my test code, if that helps:
    Dim stabApp As New BentleyStability.Application
    Sub testDamage()
    Dim thisTank As Tank
    'stabApp.Design.DamageCases(1).IsDamaged(1) = True   '--> this will give an error becasue damage case 1 is actually the "all intact" base case and we can't set anything damaged.
    stabApp.Design.DamageCases(2).DamagedPercent(1) = 100 'this works
    stabApp.Design.DamageCases(2).IsDamaged(1) = True 'is better syntax if you aren't using partial flooding.
    'I often use For Each loops, not that I've defined thisTank earlier on.
    For Each thisTank In stabApp.Design.Tanks
        stabApp.Design.DamageCases(2).IsDamagedByName(thisTank.Name) = True
    Next
    End Sub
    Answer Verified By: Oliver Cooper
