Good morning,
I am very new to the SACS software and licensing system. I have a SACS Structural Advanced license and I am following the tutorial on LEARNserver, called: "Jacket Type Structure - Linear Static Analysis".
Even if the tutorial is in the section "SACS Structural Advanced" it contains joint can checks, so when I try to run the model I get an alert as follow:
I unchecked the box "Edit Tubular Joint Check Options" but I still get the error.
My question are:
1. How can I run the analysis removing joint checks?
2. Where can I find tutorial specific for my license?
3. How can I lock all the feature not included in the license? I would like to avoid a situation where mistakenly I use I license I didn't pay for.
Daniele
Hello Daniele,
A: Just leave the "Edit Tubular Joint Check Options" unchecked. Ultimate license is required for Seastate program to calculate hydrodynamics forces. That is why you are seeing this window.
A: There is no tutorial specific for this license. In Advanced license you have permission to run environmental loads only for wind profiles. You should consider this.
A: This license window will always show up when you try to run anything that is not included in your default license. If you click "Yes", it is going to use a different license.
Rafael Lara
