Hello everyone,
I hope all of you is fine
I want to ask a short question. After setting the model in modeler, I save it on the desktop. When trying to save the file in another folder, I get the following warning.
How can I save the model in another file, I don't want it to stay on the desktop all the time. Also, copy and paste does not work.
Best Regard.
I wouldn't recommend using brackets or periods in your file paths. See if the problem persists when you have no special characters in your file path.
James
File name is ' Kalkimli Form '
Also, only open on the desktop. When trying to save the file in my PC storage, I get the same warning again
try a file path without these:
I tried but it still didn't work. It works when copy it one by one and paste into the storage unit.
