How to define difference marine growth profiles for those members which are in the same elevation range.
i.e I would like to define 5cm to braces and 7cm to legs for elevation +1.6m to -20m.
Hi Nisachol,
Can you tell us which software you are using?
Thank you,
Georgina Maldonado
SACS 14.2
At this point of time, we don't have an option to define different marine growth profiles within the same elevation range as per what you have in corrosion zones. You can use the member/group overrides for that purpose, but it will change the entire member/group not according to a specific elevation. Regards,Nurfaiza Mat
