Hello everyone,
I'm trying to create the structural elements of a boat with the Maxsurf Modeler. Frames, decks and plates are added but I can not add stringers correctly.
I want to add it on a straight line, but it is added on plates.
Below is what Maxsurf created (white lines);
Below is where I want to add stringers (pink lines);
How can I add longitudinal elements as I want?Best Regard.
Is this Screenshot from Rhino? Are the stringer incorrect in MAXSURF also?
If all the stringers on a surface are incorrect, it is probably caused by the outside direction of the surface being the wrong way around (use Display | Outside Arrows to see).
If it is just individual stingers, then check that their orientation is correct using the parts table.
James
Hi James,
I solve it with Display | Outside Arrows.
Thank you, if any more question, I will ask.
Best Regards.
