I am trying to view Member UC for several different volumes in the Precede results view.
After I have set my first volume and then I view the Member UC results via the Labeling options, I can see the results. Refer Step 1 figure below.
However, when I change the volume to the next one that I want, the Labeling options window becomes blank. Refer Step 2 figure below.
This happens even if I reset all in the Labeling options window before I change volumes. And I also noticed that the tet "For All Active LCs" remain even when resetting without changing volume.
This disturbs my reporting workflow because I need to reopen the results in precede, set the selected group and members, volumes etc.
Step 1:
Step 2:
SACS version:
Hi Ibrahim,
I have tried to reproduce this error but i could not. Have you tried another model or updating to realease15.0?
Rafael Lara
