Hi everybody!
I am reading and follow the manual call Learning maxsurf manual.
In chapter 5: Designing in Maxsurf. There is a section called starting a design_ Video.
You can click web or disk. When I click web appear videos but not that video. This is the web I am sent:
www.bentley.com/.../maxsurf
When I click a disk, appear the image that I attached.
I would like to find the disk of the learning manual.
Can you help me?
Thanks in advanced.
MJ
Sorry,
Is there any current manual that has the link to videos?
No, there are no videos linked with the manual -- all the videos are now on youtube, we have organised them into playlists that cover different topicsBentley Offshore Analysis - YouTube
the channel is shared with MOSES and SACS so make sure you look at the MAXSURF videos and playlists
Answer Verified By: Maria José Legaz Almansa
Yes thanks again.
Maybe this is a reasonable place to start: MAXSURF Modeler - Planning a Surface Layout - YouTubeYour screen shot looks like it is from some very old training material we had many years ago :-)
I found the old training material you were referring to and you can download it here:
Learning MAXSURF - Self-paced training material from 2011 - MAXSURF | MOSES | SACS Files - MAXSURF | MOSES | SACS - Bentley Communities
communities.bentley.com/.../learning-maxsurf-manualLearning MAXSURF - Self-paced training material from 2011
This is somewhat dated self-paced training material that we created in 2011. However the underlying principles of how the software works are essentially the same. In the newer versions of MAXSURF you will find an updated user interface and many new commands, so there are possibly alternative ways of doing things these days.
This training material will give you a good introduction to modelling with NURB surfaces in MAXSURF Modeler. It contains a pdf document which takes you through the various steps and also some short video clips which demonstrate the various topics described in the text.
Don't forget that there are also many instructional videos on our You-Tube channel: Bentley Offshore Analysis - YouTubewww.youtube.com/.../playlists
