Hi I have a problem after i body plan in 3D using sp lines or polylines for curves and save it as Dxf file my maxsurf modeler can’t recognize that file with normal ordinates and appear strange directions for markers or curves which i can’t use to make a surface
Hi Mohammed,
Do you get this dialog when you use File | Import | DXF Curves?
Not all softwares use the same orientations (x may be fwd, port, stdb etc.), so we have the ability to change the assigned directions using this box. Change the directions by changing the assigned XYZ radio buttons. It often takes a bit of guess and test to get it right.
If you want to import your surfaces instead of curves, use IGES format.
James
screengrab.
