I seem to have a problem getting a result with respect to the Margin line immersion – Equal based criteria.
In the results window it reeds: status Not Analysed
Hi Mohammed,
please be aware you posted your question to general Developers and Programming Forum.
Please follow the best practices and to specify exactly what product and version do you use, because from your question it's not clear at all.
Depending on used product, I recommend to move your post from this forum to the right one. To move existing discussion to another forum, use More > Move tool available under your original post.
With regards,
Jan
If it is telling you it isn't analysed, have you analysed it?
Remember that some criteria are going to be based on large angle stability, some on equilibrium conditions. So you will need to run your Equilibrium analysis to get you equi based criteria to calculate.
James
have you done an equilibrium analysis and does your model have a marginline ? please submit a support request with your model and settings for a more accurate diagnosis
