Can SACS be used for dynamic analysis of a centrifugal compressor located in a PAU. PAU been design using STAAD Pro?
What module of SACS I need to use and are there any step I need to carry out the work.
I have used SACS before but not for dynamic analysis. What information I need for the compressor (which I have the datasheet for) to input into SACS, if it can carry out the dynamic analysis I am trying to do. Can you link me a A tutorial or an example from SACS it would be appreciated.
You can perform a dynamic analysis of engine or compressor vibration with Dynamic Response which requires the Fatigue Advanced - Dynamic Response license. Information about the analysis, required input, and output are in the Dynamic Response documentation. You can review Sample 3 of the Dynamic Response documentation or Sample 10 from SACS Executive Projects > Projects > Open Sample Project.
