I want to calculate dynamic stability by using MAXSURF Stability Module. Could you please tell me what is the input need to calculate dynamics stability?
Thanks in advance.
When you say "dynamic stability" do you mean the area under the GZ curve up to a certain angle?
If this is the case, you can calculate this data with a Large Angle Stability analysis.
There are options to tabulate and graph the "dynamic stability"
