Is there any simple example of probabilistic damage stability?
 Hello.
I mean, a done case in which I can show how to work with probabilistic damage stability and the written tutorial.
In the negative case, I have tried to set up a simple case. but it fails to run probabilistic stability analysis and I do not why.
The program says please check the loadcases for probabilistic damage analysis.
I attach a screenshot of the loadcases.
I have only tried to do a simple example.
I could also send the file if it is needed.
Thank you in advance.
Best regards,
María
