dat & cif.zip
I'm trying to model a semi-submersible using &surface command. After that mooring analysis must be done, but im getting an error, where model is not showing after using mooring commands. I have attached the (.cif & .dat) files used. I'm stuck with the error, im unable to proceed further.
Hi Sai Kumar,
Have you tried using the new MOSES Modeler. It had many new features in MOSES version 12.02.
Georgina Maldonado
jjj.zip
Hi, it is me again.
Attached is jjj.zip. These files were bases on the files you sent, the mod00001,txt resulting from one,cif was copied to jjj.dat. jjj.cif was based on you original cif.txt.
I hope this helps.
Hello Georgina, Good day
I have moses V10.10 and well noted your zip file. It is working fine. In the provided .dat file i found point coordinates and define panels to model a semi submersible. But my question is how can i do mooring with &surface model? If so how can i do it and please use my zip attached earlier to provide me a solution.
And also can you help me how did you get those point coordinates and define panels in .dat file?
Hi Sai Kumar, The &surface menu is intended to create models. The &surface menu creates the mod0001.txt file. The intent is to create the model, then in a 2nd command file do the analysis.
I did not understand your statement, "i found point coordinates and define panels to model a semi submersible".
For you last question, please run one.cif. Copy the resulting mod0001.txt file to jjj.dat.
Hello Georgina,
Thank you so much, It helped.
