young's modulus AE showing when i input command @status cl_flex. i want to know how moses is calculation modulus of elasticity value. if there is any formula i want to know.
Hi Sai Kumar,
The &status cl_flex command is available only for flexible connectors. The assumption is that the cross sectional area is circular. You can use an option to input an area. There is also a default E. You can use an option to input a value of E. Once those are calculated or read via an option there is multiplication.
I hope this helps.
Georgina Maldonado
