Dear all, When running the transfer function plots option with seastate I get a chart showing the points base shear/wave height. When checking I noted:
seancf file base shear/wave height for a period X=16 sec reads Y=1268.489 KN/M I.E. implying H x 1268.489 = 17.131x1268.489 = 21730 kN base shear.
when reading the listing file for this case:
Max base shear equals 10997 kN wave height 17.131 m >> 10997/17.131 = 640 i.e. >> does not match 1268 the plot.
So my query is, how can I calculate back the plotted transfer function dots in my SACS listing file to my opinion I should be able to retrieve the same numbers.
Thanks alot. kind regards, Robert
Transfer function is Range (Base Shear) / Wave Amplitude. It is NOT wave height.
1268*17.131/2 = 10861 ~ 10997 kN
It is not match as I do not know how you get 10977kN. You cannot directly get the base shear from wvrlst.
It is a Range of Base Shear..... Then,
BS Range in X = Max. Base Shear X-dir. - Min Baseshear X-dir.
BS Range in Y = Max. Base Shear Y-dir. - Min Baseshear Y-dir.
BS Range = (Range in X ^ 2+ Range in Y^2)^0.5
RAO shown in ncf is BS Range / (0.5*Wave Height)
Answer Verified By: robert pluim
