#amass in moses
Hi, everyone:
In the moses manual ,the #amass is explained as above.  for the parameter DISP, it says that the added mass will be DISP/G.
when the analysis is under a SI unit ,  the added mass has a unit as MTON, so the DISP's unit  in the #amass should be MTON*G ??
For  example, if i has a launch barge whose amass is 5000mt. Should i type the commond as follows:
#amass   *pt   5000*9.8   cx   cy   cz   rx  ry  rz
thanks for your reply!
Parents Reply Children
