I have added additional forces heeling arm due to fire-fighting and thruster in the parent heeling arms list as per picture attached.
However, the heeling arm is not been considered into the criteria as i want to check the "maximum ratio of GZ to heeling arm" and the "angle of equilibrium due to this heeling arm". I tried with different heeling arm criteria from the criteria list but the results are not analyzed. Is there other methods to get the results?
Hi Benedict,
Two things to set you straight here:
- Instead of working with the parent criteria, create a new group and copy the parent criteria and heel arms into it.
- Heeling arms need to be in the same group (folder) as the criteria that refer to them.
Take a look at the attached library (In Stability, use File | Critieria | Import Main Criteria)
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/343374/my-Criteria-Library.hcr
James
Answer Verified By: Benedict Ee
