In a simple barge analysis, how to export the picture of inside compartments /tanks in MOSES?
Thanks.
pics.zip
Hi Ravi,
If you are looking for a command, you can use the command "&picture view_data -type compart -options". It is up to you to put in the view_data and other options.
If you want a GUI way of doing it, please see the attached screenshots. One screenshot shows the setting for the rendered window. The other screenshot shows how to control the position and the zoom.
I hope this helps.
Georgina Maldonado
Dear Georgina,
Thank you so much. Now I am able to view the compartment.
Is it possible to view the section of the ship at a specified location/ distance ?
That is where you need to set the view_data. It takes three numbers. You can also use the other options to focus on an area.
