moses structural reactions
I'm trying to perform a structural check of an item before load-out.
The item is fixed on nodes *S1 to *S4.
The overall weight of the ITEM is 1569 tons
+++ F O R C E S A C T I N G O N I T E M +++
Process is DEFAULT: Units Are Degrees, Meters, and M-Tons Unless Specified
Results Are Reported In Body System
Type of Force X Y Z MX MY MZ
Weight 0.00 0.00 -1568.65 0 23888 0
Inertia 0.00 0.00 1568.65 0 -23887 0
Total 0.00 0.00 0.00 0 0 0
The weight is supported on 4 legs (B1 to B4), and is practically centered, so each leg support point should have a reaction equal to 1569 ton /4 = 392 ton.
But the axial load computed by moses on each leg end is 307 ton.
+++ B E A M L O A D S T A N D A R D +++
Units Are MPA, Degrees, Meters, and M-Tons Unless Specified
Forces For Most Severe Load Case with Axial Load Greater Than 0
% Dist Axial /------ Shear -----/ /---- Bending ----/ Pressure
Element /-- Node Names -/ Class Case From A Load Y Z Torque Y Z
B1 *DT1 *S1 ~BEAM SW 100.00 -306.51 4.71 -7.64 -0.00 -57.55 -34.49 0.0000
B2 *DT2 *S2 ~BEAM SW 100.00 -306.51 4.71 7.64 0.00 57.55 -34.49 0.0000
B3 *DT3 *S3 ~BEAM SW 100.00 -307.59 -4.71 7.95 -0.01 59.86 36.53 0.0000
B4 *DT4 *S4 ~BEAM SW 100.00 -307.59 -4.71 -7.95 0.01 -59.86 36.53 0.0000
I cannot explain the reason for such a large difference between the expected ground reaction and the obtained axial force at column's base.
Any hints?
Thanks in advance,
Doug
EDIT: SOLVED, THE PROBLEM WAS THE FACT THAT A NODAL WEIGHT WAS DEFINED AS A LOAD_GROUP (IT WAS SMEARED ACROSS MULTIPLE NODES). THE SOLUTION WAS JUST RESTRICT TO THE LOAD_GROUP TO SPECIFIED NODE
&DESCRIBE LOAD_GROUP ITEM *dt5
#weight *dt5 766 15 20 18
THE ISSUE CAN BE CLOSED.
