Hi there,
I noticed that in v15.0 the name of master-slave has been changed to retained/constrained in Precede. Could you please kindly confirm the following questions?
1. iIs master-slave being made obsolete and replaced by retained/constrained joint?
2. if yes, is retained/constrained working the same way as master-slave?
3. I read in the manual SACS 15 for retained/constrained that "coupled joints should not be coupled for all degrees of freedom, typically. distinct points may be forced to displace similarly but may not rotate similarly." what is the consequence if I restrain for all DoFs?
4. Analysis with master-slave script sill can be run successfully in SACS 15.0 , but there is no line assistance in datagen for master-slave. is this correct?
thanks in advance.
Kind regards,
Jacqueline
Yes, it is being replaced by Retained/Constrained.
Yes. It works exactly the same, just the naming is changed.
SACS just provides you suggestion. Depending on your structure or the way you like to restrain, SACS gives you the option to restrain all degrees of freedom. Please refer to Section 2.8.2.5 Retained Degrees of Freedom in SACS IV manual for full information.
Please rename MASTER to RETAIN in Data Generator manually to see the Line Assistant. This will be updated in future release. Please also refer to SACS IV manual for the RETAIN card for detailed information.
