Dear SIr,
I am trying to perform transport fatigue analysis. I found an article which shows the transfer function plot from tow analysis. But I can not find a way to do it. Can you please help me in this regard?
Hi Gargi,
Can you provide more background to your question? What software are you using SACS/MOSES/MAXSURF?
Which article are you making reference?
I am trying to extract transfer function for each joint from SACS so that I can use it for further checks I want to perform.
I found the following article which describes that its possible
Tow Fatigue with SACS - MAXSURF | MOSES | SACS - Wiki - MAXSURF | MOSES | SACS - Bentley Communities
But unfortunately, I cannot figure out how.
