Dear Bentley Team,
I am trying to run a 'Basic static analysis' of an existing model on the 'SACS Offshore' but it displays warning of utilizing 'SACS Offshore ultimate. Can I get some help on this?. See screenshot attached.This model was analyzed with PSI file on 'SACS Offshore Ultimate' previously.
Also, Is there any support services that can be utilized for licensed software for small queries?. Thanks alot.
Hello Syed,
For a basic static analysis, SACS can determine whether environment load calculation is needed automatically based on related commands defined in your model. In your input model, the LDOPT line is used to define seastate related options. Please remove this command from your input file if you don't want to perform environment calculation.
You may raise a service request via Creating a new Service Request - Licensing, Cloud and Web Services Wiki - Licensing, Cloud and Web Services - Bentley Communities
I hope this helps!
Regards,Nurfaiza Mat
