Dear,
Please advise what theory has been used for the Drift Method of 'Formulae' in the wav_drift.cif file?
Hi Mustofa,
You are using the command "g_pressure bname -md_type formulae"? That is an undocumented setting.
This value has been deprecated. We no longer support the use of that value.
What files are you working with?
georgina
I was referring to files of wav_drift.cif and wav_drift.dat from C:\Program Files\Bentley\Engineering\MOSES CONNECT Edition V12\hdesk\runs\tests\force where it is not g_pressure but "g_mdrift barge form -md_type form", therefore I am looking for the detail of 'form' to compare with other drift methods (near field, far-field, salvesen).
This is going to take me some time to find. This option is now deprecated. I will have to look in the archive.
Georgina Maldonado
