What software can you recommend for viewing .eps files? I was using GSView, but it doesn't work anymore and I wouldn`t mind switching to a more user-friendly software.
Thank you,
Berislav
Hi Tusek,
I too have been having difficulties with GSView. Postview is so much "prettier". I know pretty is not a good term to use without a definition. I do find eps files cleaner.
I have tried downloading the latest from GNU. But that seems to also have quirks.
I have started just viewing png and jpg.
Georgina Maldonado
Hi Georgina,
Thank you for your answer. After having no luck with GSView, I tried using Acrobat Reader and it worked wonderfully. The quality is much better, converting to pdf format takes less time and all the pages are put in a single pdf file, so it is very easy to scroll through.
Best regards,
Thank you for writing back. I will try that also.
Cheers,
Georgina
