Maxsurf stability advanced
I have a problem that after i made model in maxsurf modeler advanced and put AP,FP ,DWL ,the Maxsurf stability advanced not calculate hydrostatic for my model even though read tanks inside model and calculate it
  • Hi Abozeid,
    You haven't given me much to work with here. Can you tell me more about what is happening here?
    The first question, is have you checked that the hydrostatic sections are formed correctly?
    Which analysis are you trying to run? Have you configured the correct settings under the Analysis menu for that analysis type? Upright Hydrostatics is one of the simplest to run.
    Perhaps you can post some screenshots to show what you are doing and what the problems are.
    James
