stiffener modeling of plate girder(I-shaped)
I have a question for modeling of SACS program.
It is a Beam Model of 2 joints and 1 member.
-Z direction load above beam top.
because of this, I try to add plate stiffener 10t to increase the shear area of beam web.(please refer to figure below.)
1) in second figure, i understand i can apply spacing value at "Stiffener Spacing(m)" of Edit Member Group XX window.(but i am not sure it is right procedure.)
    If if is right, in addition to Spacing, i wonder how to apply the properties of stiffener with which command card.
2) If 1) is wrong, how i can approach the modeling method for that beam.
3) i did like this...
  a) divide every length with different section in segment
  b) the modeling is like (I-shaped steel) - (I-shaped steel + stiffener) - (I-shaped steel) - (I-shaped steel + stiffener) - ......
  c) I failed to open "detail report" of beam at postvue after analysis run.
     I am not sure that too many segments made the problem or another error.
please reply if you have a key for this problem.
