The following presented the example of the MOSES Output for Tubular Joint Fatigue. Based on this, the upper and lower CDR is for Brace and Chord respectively. It is understood that, the Joint *J1359 - Node *J2031 is belong to the Brace Element.
Question; How do we identified, Chord detail i.e., Node, Element and Class belong to, as highlighted in circle and "X" ?
Note:
In SACS, normally the Joint, Node & Class were presented for both Chord and Brace accordingly.
Hi Haydar,
Thank you for your question. How about trying the command FATIGUE under the STRPOST menu? You can use the SACS Fatigue module in MOSES and it also gives you fatigue results in SACS format. Please refer to the manual XXVIII.G Post{Processing Beams for more information.
Best regards,
Bitna
