I am having the same problem.
But, I found a workaround. You can prepare and save a Measurement (".hsd") file with the calculation methods pre-selected.
In MATLAB, instead of selecting the method, you can load the ".hsd" file using hsApp.Design.MeasurementsOpen("example.hsd").
Thanks. I will try this way.
hi -- Make sure that you have the correct version of MAXSURFresistance.exe registered as the COM server and also that its properly connected to MATLAB. I have not used MATLAB so am not sure how you do that (in Excel / MS Office you need to go to the Tools menu in the VBA editor, References, then select the correct executable).
Note also that sometimes it needs some fiddling to get communication between 32 and 64 bit applications (is your version of MATLAB 32 bit?)
this document expalins in more detail, but the main steps are outlined below
MAXSURF Automation COM Troubleshooting - MAXSURF | MOSES | SACS - Wiki - MAXSURF | MOSES | SACS - Bentley Communities
So yo ensure the correct version of MAXSURFresistance is registered, open a command prompt with admin rights and go to your installation folder. The type 'MAXSURFresistance.exe /reg' and check the message comes back as follows:
Then in Excel (or equivalent in MATLAB) go to the VBA editor, Tool | References and brows/select the MAXSURFresistance.exe you just registered:
you should then be able to go to the object browser and see the different methods
there should be a similar process / steps in MATALB I would Imagine
cheers,
Pat
Dear Pat,
I have checked, correct version of Maxsurf Resistance is properly registered. Still, I cannot find the options as mentioned earlier.
can you check in Excel VBA object browser - thanks
