For the diploma thesis, I need access to the script of the methods in the Resistance module. At least four of them.
I do not know what programming language is used, either.
There are other programs in which to access the script is easy, no the case of resistance.
How this can be done? I mean, How access to the scripts?
Thank you in advance,
Best regards,
María
Hi Maria,
Do you want to use MAXSURF Resistance via an external program (i.e. use Excel VBA to communicate with MAXSURF via COM).
If so take a look at the Automation Samples in C:\Program Files\Bentley\Offshore\MAXSURF CONNECT Edition V23\Automation Samples
If you want to take a look at how the resistance calculation are done, then read the references section of the Resistance Manual.
James
Hi James,
Thank you for your answer.
I have seen the automation Samples. There is not any example of the resistance module. I attach the screenshot.
Can you provide at least one example of the resistance module? I mean the excel where the VBA is opened.
Thank you in advance.
Maria.
