Hi
I'm trying to automate MAXSURF modeler so i can modify a hull shape with a parametric transformation and get its hydrostatic results written in an excel file, and after that save it as a file called test , so i can learn to use it.
However I've written in visual basics the required commands to open the design , make the transformation and get the results ,and when i execute it, it appears error '-214722164(80040154)' .
This is an screenshot of the written code and another were it appears the problem.
Sorry that it's in spanish.
Hi Juan,
I'm not sure what that error message says, but does this error occur at the first line using MAXSURF? It may be that your References are outdated.
Try following this youtube instructions:
https://www.youtube.com/watch?v=hBkpIe2dojI
James
I did what the video shows.
However it says that the registration was unsuccessful.
It seems that there's an issue with the license
Thank you anyways
This error message to "Check Permissions" is your user permissions in Windows.
6m32s in the youtube video - run Command Prompt as the Administrator.
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
