SACS - How to change Joint number in batch in PRECEDE:
EG: I want to change all joint number between (1000~2000 to 5000~6000).
Thanks.
you can use "joint reorder" in precede (go to joint tab under action category). however, it needs to be changed plane by plane. have a look and try yourself.
