Is MTc in Maxsurf calculated using LBP or LWL?
Hi Kasia,
We use the Lbp.
Trim is measured as the change in draft between AP and FP. So measuring the moment it takes to change the draft between the AP and FP by a centimeter needs to use the Length between AP and FP, hence Lbp.
James
I should point out, while we are on this subject. You can use Data | Coefficients to tweak which values are used in the calculation of some of the other coefficients.
Thank you for your reply.
