Is it possible to change Coordinate system in Maxsurf Stability to:
Transverse: -ve stbd +ve port ?
Sorry - coordinate system is fixed in MAXSURF.
Some of the File | Import options, such as IGES and DXF allow you to select which imported axes are which direction and which way is positive so you can get your model right in MAXSURF.
Thank you James. I understand that Starboard is always "+" in Maxsurf Stability. Correct?
