Every other method gave results but i need Holtrop Mennen specifically. Model is from Maxsurf's own sample designs, it is Ship_Pro with the parameters transformed. L=112,4 B=16,23, D=10,14 and Displacement is 6050 m^3.
Hi Alper,
It should calculate. Did you check the Data window to confirm that the hull has been measured correctly?
In mine, I can see that the Beam is low, draft is high. These are warnings and the rules will still calculate.
James
The methods that are provided in Maxsurf are an approach for some ships dimensions.Try to see where your ship's model category belongs to based on your Froude Number and Hull Ratio (L/B, B/T, etc.)The Maxsurf Resistance itself will give you some warnings even it will still calculate your models.It is commonly happened if you "forced" some methods to some ships that are not belongs to the category, especially due to the Froude Number (Displacement, Semi-planning, Planning, etc.)
