Limiting Maximum Rocker Arm Tilt Angle
Does MOSES have a way of limiting the maximum tilt angle when only primary rocker arms are used?
As specified in MOSES manual,  "If there is no secondary tilt beam, one should omit the values for MAX_ANGLE, TSECDEP, and DIST".
For my case study, the allowable maximum tilt angle is 16 degree as per rocker arm and barge configuration.
Thank you.
Faizul
Parents Reply Children
