Is it possible to choose what results are shown on the Graph of Longitudinal Strength Analysis? Exclude Mass, Boyancy and Net Load for example.
Hi Kasia,
Could you let us know the name of the software you are using now? It MaxSurf or MOSES?
Best regards,
Bitna
I had never noticed that you can't alter this graph!For other tables and graphs, you can change the visible plot lines, rows and columns using Display | Data Format. However, for Longitudinal Strength it isn't enabled.
Let me talk to the Development team and see if this is something we can add.
In the meantime - I don't think there is much you can do other than move the data to Excel and crete the graph there.
James Clarkson
Answer Verified By: Kasia Milewska
Thank you James. I will just use the Maxsurf graph for now.
I use Maxsurf
