Hi there. when i run my simulation the time domain stop. the error show stop due to capsizing. how can i improve this as my model is very small. it is a cylinder with lenght of 3m and diameter of 1m. hope you can help. below is my code.
$$ Analyze single floating Photo Bioreactor$$************ Set Basics$&device -oecho no&dimen -dimen meters m-tons&title Sample of Multi-Point Mooring on floating Single Photo Bio Reactor$$************ Insert Model$inmodel&describe body ko$$********************************************* set initial condition$&instate -condition ko 0 0 0$$********************************************* define mooring lines$medit *mla 1.5 -0.5 0 *mlb -1.5 -0.5 0 *mlc -1.5 0.5 0 *mld 1.5 0.5 0
~wire b_cat 20 -depanchor 50 -len 200 -buoydia 0 -wtplen .0125 \ -c_sn wire connector a -anchor -45 20 ~wire *mla connector b -anchor -135 20 ~wire *mlb connector c -anchor 135 20 ~wire *mlc connector d -anchor 45 20 ~wire *mldend&connector @ -a_tension 100$$$****************************************************Enviroment data&set Hss = 0.001&set heads = 0 &set Tpsmx = &number(sqrt %Hss%*30) &set Tpsmn = &number(sqrt %Hss%*13)&set Tpsmd1 = &number(real %Tpsmx%+%Tpsmn%)&set Tpsmd = &number(real %Tpsmd1%/2)&set Tps = %Tpsmx% $%Tpsmn% %Tpsmd% %Tpsmx% &set WSPEEDS = 0.001 $10 15 20 $************** KNOTS&set cur = 0.5144 $************** m/s &SET TSPEEDS = 0 $0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.5 2.0 $************** KNOTS
&set time = 500 $ times=1800 for full run$&loop ii 1 &token(N %Hss%) 1&set Hs = &token(%ii% %Hss%)$&loop jj 1 &token(N %WSPEEDS%) 1&set wind = &token(%jj% %WSPEEDS%)$&loop kk 1 &token(N %TSPEEDS%) 1&set towsp = &token(%kk% %TSPEEDS%)$&subt Tow Resistance Hs=%Hs%m, Heading=%heads%deg, Tp=%Tps%sec, Vwind=%wind%knot,Towspeed = %towsp%knot, Curr = %towsp% m/s &type&cutype Hs=%Hs%m, Heading=%heads%deg, Tp=%Tps%sec, Wind=%wind%knot, Current=%towsp%knot&type&stat f_connector -both&even 3$&eofile
&ENV NULL&ENV %heads%_DEG -SEA jonswap %heads% %Hs% %Tps%/1.2958 3.3 -wind %wind% %heads% -current %cur% %heads%\ -tim %time% 10 $ -water 997*9.8066500286389$&equi -maxit 9999&status env&status env -h&status forc -h$****************************************************** TIME DOMAIN&ENV %heads%_DEGTDOM -new&DCPTIME Time For Time Domainprcposttrajectory -EVENT 0 %time% $150*8.366*2 0.5*2 vlist statistic 1 5 6 -ha plot 1 5 6 -no_edit $end report -EVENT 0 %time% $150*8.366*2 0.5*2 end CF_MAGNITUDE -EVENT 0 %time% $150*8.366*2 1$ $ vlist statistic 1 2 4 6 8 -ha plot 1 2 4 6 8 -no_edit report -EVENT 0 %time% $150*8.366*2 0.5*2 endend&endl&endl&endl&eofile$&fini
Hi Georgina,
Thanks for the command. Ive tried it and it works. But i encounter other problem. My model appear below the sea surface and its also appear to have a large rotation. can you suggest anything to solve the problem?
You should make a picture after the &equi command. I see that you have commented out that command. You should be happy with the results of the &equi command before starting the time domain analysis. In university this is where the professor would say, solve the static analysis before proceeding to the dynamic analysis.
I hope this helps.
Georgina Maldonado
