Hello,I have this error when I run static analysis :*** ERROR - LABEL INCW NOT RECOGNIZED AS PROPER*** ERROR - LABEL ACCE NOT RECOGNIZED AS PROPEROn these lines :* GRAVITY - OPERATINGLOADLOADCNOPEGINCWGT PLATACCEL 1.00000 NI don't understand because I correctly defined the weight group "PLAT".I got these command lines from a file which works.
Philippe
Resolved.
This line was missing at the beggining of the file :
LDOPT NF+Z 7.850000 GLOBMN NPNP
The density was missing, then SACS don't can apply an acceleration...
