Suppose I have a hull with 6 surfaces. I want to know the coordinate (x Value to be exact) of the control point (row=1, column=0) of the first surface. how can I get this using automation?
I am trying the following code.
msApp.Design.Surfaces.Item(1).GetControlPoint 1, 0, CPx, CPy, CPz
But getting this error.
Dim msApp As New BentleyModeler.Application Sub NewPt() Dim CPx As Double Dim CPy As Double Dim CPz As Double Dim FN As String msApp.Design.Surfaces.Item(1).GetControlPoint 4, 1, CPx, CPy, CPz End Sub
Answer Verified By: Rounak Niloy
