I have done the design in rhino and exported it to Maxsurf. I created a design grid and calculated the offsets but still I cannot see the offsets. I am attaching my modle file. I hope you can verify it help me with my problem Thank you.
https://drive.google.com/file/d/1eZ1xS3yq8QmVwBOh7rI8kP2wZ3KczgJg/view?usp=sharingThis is the drive link to access the file.
Offsets are only calculated for NURBS surface models, the design grid must intersect the surfaces
the offsets should be in the table, you can go to each section in turn using the Data menu - maybe the section grid does not intersect the model?
otherwise please submit a support request Bentley.com - Technical Support
if you want all the offsets in a single table, you can either export. Or you can generate markers to see where the offsets have been calcualted:
