Combine the loads generated by weight definitions and the environmental loads in SACS
Dear All,
I am following the "Jacket Type Structure - Modeling Loads Using Weight Feature" tutorial from the "QuickStart for SACS Offshore Structure" Learning Path.
In this tutorial, dead and live loads on the structure are defined by first defining the surfaces to SACS and then defining pressure values on the surfaces.
Following that, environmental loads are defined in the program.
My problem: I can't see the dead and live load conditions when I try to combine them with the environmental loads (wave, wind, etc.) Since the dead and live loads are defined as WEIGHTS, they are not in the LOAD combination list, as seen in the screenshot.
Does anyone have any idea?
Thanks in advance.
Parents Reply Children
