SACS unity check weird value ?
Hi, I have run my model and I am getting failures of some members. When I checked them, I found out the ratios below. Then I run it again because I thought something is wrong, but I get the same result.
I always thought that the unity ratio is the Actual stress divided by Allowable stress, but here somehow those numbers give a result of 100.05. Can someone please explain why?
Thank you in advance.
Agata
Parents Reply Children
