Dear all,
I would like to know if it is possible to calculate the Pitch, Roll and Yaw rotation inertias (kg/m^2) of a floating structure using MaxSurf since I am trying to create an OpenFAST model and need them.
Thanks beforehand.
Ivan
Hello Ivan,
It is not possible to check Pitch, Roll and Yaw rotational inertia directly. However there is some data available, which you may find helpful to perform these calculations. In MAXSURF Modeler go to Data | Calculate Areas.
The table can help with hand/Excel calculations, if no other option is available.
I hope this helps.
Aleksandra Roslon
