In SACS V16, it seems the joint displacement labeling results are only available for the maximum out of all the load case selected (active). Unlikely to the max member UC that can be displayed for each load case selected, separate runs with the interested load case need to be done to see the joint displacement labels for each load case (In the V16 version at least).
Can this be improved? Is there a way to get the joint results for each load case selected in this version?
