psi input error - error system
hi
can you help with this error in static analysis with psi input
thank you!
  • Hi.
    If there is no issue with your model file (hope you have checked your model for any possible errors) then the following solution might work.
    1. Try taking a normal static run. This might help to identify any issues in the model itself. If that's all fine then try next point.
    2. The P-Y data which we enter in psi should be in ascending order. Refer the pic below.
    If you observe in the pic the P values are starting to reduce after the 5th reading. If you have such cases in your psi data correct it and keep the last highest P value as constant for all the following readings. This has to be done for all the data.
    Hope this helps!
