Hi all,
Is there a way of inserting a picture of the current tank status in profile and plan view while creating Maxsurf stability reports? At present, the reports are plain with no figures. Competitive stability software are able to insert the graphic automatically. Refer screenshot below as an example. Your valuable guidance in this regard are welcome.
Hi Abin,
Yes, it is possible to insert a picture of a tankplan in MAXSURF Stability Reports. You can read more in Stability Manual p. 242-246.
You can also find Stability Booklet Template. Default location is C:\Program Files\MAXSURF\Report Templates\
If you want to use Stability Booklet Template in MAXSURF Stability go to Results | Reporting Options and tick 'Use Word Templating'.
I hope this helps.
Aleksandra Roslon
