Dear Georgina,
How mooring line (B CAT, H CAT) lines are modelled in Moses, whether using the finite element approach or some other theory. I read through the Moses deals document, but there is insufficient explanation. Please clarify.
Hi Sai Kumar,
The elements modeled with B_CAT and H_CAT only depend on the catenary shape to calculate the tension.
If you are looking for a finite element approach please see the ROD elements.
I hope this helps.
Georgina Maldonado
